Hi all, I want to re-wire a Strat using the existing components, but with a form of blend wiring. My idea was to re-purpose one of the tone controls as a second volume control for the blend function, and hang this second volume control off the second wafer of the switch (right hand side of the attached picture), to which the appropriate pickups would be wired by jumpers from the left hand side of the switch. The outputs of both sides of the switch would then feed the regular volume control, with a master tone control wired in parallel. The reason for all this is that I would prefer the volume of whichever pickup is being blended in to be controlled like a regular volume i.e. off at zero and fully on at 10. I would also like to avoid buying a no-load/blend type pot which seems to be a requirement of the various diagrams I've seen elsewhere on the web. So, will it work?
https://i.imgur.com/m2ndZDm.jpg
Sorry!
Would it work if you used a genuine 2-gang blend pot for the blend control, instead of reusing a standard volume pot?
No. It would still ground either the neck or bridge pickup at one end, so then either the 2 or 4 position won't work.
http://www.mojotone.com/support/Schematics-for-Pickups-and-Guitars/wiring-diagram-strat-blender
and it does work very nicely indeed, and is pretty simple to do too. I've used this circuit with both a standard 250K log/audio pot for the blend, and a 250K no load type. In theory the "no load" is the better option, but in practice I doubt it's possible to tell the difference, they both work great.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
