Lets say £500 though.
Am planning on hitting the shops to try a few (what ever gets suggested) out.
Ta
Alternatively maybe the simpler firebox would work combined with some of the pedals you already use.
I just realised that it (or any of the modellers available) filled a need I thought I had but actually wasn’t really solving my problem of getting me playing more at home in the evenings.
I'm only going to a few sounds.. Clean (add chorus & delay), crunch & lead (add delay to lead)
I have a PT mini board with tuner, two overdrives, chorus and delay.. I could plug that into something.
Thanks @John_A, let me Google the Zoom.
Cool, I think it would suit you because it's a simple analogue pedal that doesn't require programming or a weird power supply. You can also use it as an OD pedal with the speaker sim off.
Zoom G3.
that said not sure anything will satisfy you if you're a pedals into amp guy. The GT-5 direct to PA sounds good IMO - even now if you tweak it right. I have a Roland Demo CD from the 90's whenever the GT-5 and VG-8 where current and some of the sounds on there are really good. That said, I remember being impressed when I lent someone who had joined a band I was in way back - turn up with just his Mex strat...borrowed my Bad Monkey pedal and via the speaker emulated output it sounded quite good in the band mix...I never forgot that even though its like 10yrs ago now!
