Well after much lurking, I thought I'd venture out of my shell and post up some work I did last year as a bit of a project. Inspired somewhat by the modding threads on here, particularly the buy something cheap from Thomann and turn it into something nice, I fancied an old tele to play about with.
As with many things, plans changed along the way, with me first wanting something cheap as chips, bit of a bargain type thing which after many weeks of research and faffing about on what I'd like and what I'd like to do with it, I settled with my heart which loves Japanese things and ended up with a nice workhorse tele from Rob at Whistable Guitars. He had a number of good guitars available, but I wanted something that didn't look pristine so that I would actually be willing to fettle it. The only downside being that it was twice the budget I'd originally planned, hey ho!
This won't be to everyone's tastes, but it sounds good to my ears, I like the look and more importantly I had great fun doing it, bar one slip up, but more on that later. It's a bit pic heavy, but putting them up in case it's of interest or helps anyone wanting to do something similar. I'm far from a luthier although I am OK with DIY and manual type things so I was cautious and steady and all turned out well for the most part.
This sort of started from me looking at the Reverend Reeves Gabrels signature guitar, which I liked the look of, but couldn't get to see or try one at the time due to my location which seems to alienate me from nearly everything without a lot of travelling. So I decide to change tack and get this tele.
It started life as a 1987 Japanese Telecaster in black, with a rosewood fretboard. Sounded fine, but the project was burning in me so off I started...
Here's how it looked, as you'll see, nothing really to complain about!
So, first things first, time to stick a humbucker in the neck position
Started with creating a routing template out of MDF
Body stripped down
Then getting it setup in my "workshop". Thankfully, I have a very understanding partner. What with guitars, cars and computers, she lets me get away with a lot, and her common response is "well if you like it, get it!".
Cheap Lidl drill press and my drill that my parents bought me about twenty years ago, fitted with a forstner bit
Made a bit of a hole
Ready for router to smooth things out. This is where I had a minor slip up in that I put a little too much force whilst doing one of the ears which ended up moving the template across a couple of mm. These things happen, and fortunately the pick plate will cover it
Routing complete, doesn't look too bad, even with the slightly wider right hand side
So next was to get the existing paint off. I didn't want to use paint stripper and wisdom on the internet indicated that a bit of heat and a palette knife will take it off with ease. Of course it will...
The front and back came off in chips to reveal a not too nice piece of wood underneath. Too say I was disappointed at this stage would be putting it lightly. It was taking an age to get the paint off and what was underneath made me think I can see why it was painted. Chatting to a woodworking friend, he said it looked like a bit of veneer and after more reading I found that it could well be, just to help the paint take. I was doing about five square inches per evening before getting hacked off and leaving it for the following night.
You can see the sides done in this shot. They came off in nice plastic sheets, of how I wish the rest of it had been the same.
All the paint off!
Back in the "workshop" to see if it is indeed a veneer, or at least to try and make it respectable
Thankfully, it was indeed a veneer and I got through to some nice Japanese ash underneath
You've done a cracking job there, and I really enjoyed scrolling through there thinking "oh oh, what's he going to do with this??"
However, the end result is brill. Welcome to the forum - you'll fit in perfectly
Looks good and that neck pickup looks massive!
Anyway, looks very nice what you've done. It's come up a treat. For my money the humbucker looks better in chrome/nickel too, win-win
This'll definitely be one of those keepers, something with a bit of me in it, simple understate looks (apart from the massive humbucker at the neck, and a pleasure to play to boot. Strangely, it's no bigger than most humbuckers, maybe it's just down to people being used to seeing the usual thin neck pickup in its place.
I've not seen a neck pickup like that before, what does it sound like?
