You could try an E80F, which is an excellent audio valve, they’re pin compatible so just plug and play
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
I would replace the EF86 with a standard cascaded (not paralleled as in the Lightning) 12AX7 with the gain control after the first stage, which will enable you to keep it cleaner.
The plate and cathode resistor values in that Lightning schematic are nuts for a paralleled 12AX7, it's no wonder it breaks up early.
Alternatively you could use the first half (with 100K/1.5K values) as a gain stage feeding the volume control, and the second half as a cathode-follower feeding the tone selector.
Then keep the tone control connected to the volume pot and the "output" of the tone selector to the 12ax7 plate?
You have the resistor values right, yes.
People more knowledgable than me should be able to inform you better (and keep you safe/alive if your digging around in the guts of your amp)
I've got an ef86 ac15 and it works really well for me, but it's a very snarly, gnarly kind of break up with some hi-fi ish qualities in the top end.
I love it - it's not "rough" as such, but slightly wild.
I've used the resistor values from a Spitfire and popped one 12ax7 in (the power supply is less filtered than the Spitfire) kept the switcheable coupling caps (brilliant actually) and everything else.
