I prefer the Vibrolux or Pro Reverb at 35-40W, they have more solidity to the sound, even though you then can't get them to overdrive by themselves.
I tried one. Absolutely awful-sounding thing, all overcompressed mud and no typical Fender clarity whatever. The only Fender valve amp I've tried that I liked less than the Blues Junior.
The only thing to avoid with FX loops is too much gain boost - usually overdrive/distortion/fuzz pedals or external amp-type preamps, which can sometimes make the main amp unstable. (If you're using an external preamp you can run it into the FX return as long as it's not also connected to the send).
