I've got my 5E3 build running. Had a few hum niggles but mostly sorted now.
I'm using a JJ 12AY7 for V1. Sounds ok but a little noisy, maybe they all are or maybe it's the one I've got?
Has anyone got experience of others, particularly in comparison to the JJ? NOS ones seem to be very pricey so apart from JJ it looks like EH and then Harma and TAD - both of which may be rebranded EH's I guess as I think JJ and EH are the only factories making them.
Any thoughts?
TAD/Harma worth the money? If only to get a selected valve that may be lower noise than one bought at random from EH?
Don't spend the extra on the one with gold pins though, waste of time!
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
So although I'd love a good NOS example - and I'll buy one if price and circumstance are right - I think I'll order up one from TAD.
Thanks for all the replies - I'll let you know how it compares to the JJ.
The TAD seems to be the one to try first.
Cheers,
Rob
I'll let you know how I get on with the TAD, should be here in a few days. All I've got to go on is the JJ which is ok but I think it should be quieter.
Jules
The TADs are JJ, same internal structure. Probably pre-screened by TAD. Still prefer the tone of the EH in Tweed Circuits.
Worth remembering that a 12AY7 is really overloading a 0.5 watt plate resistor. Changing up to 1 watt plate resistors in my 5E3 took quite a lot of hiss and electrical noise away.
Harma's are the other option, which are from the Reflektor factory - so basically pre-selected EH 12AY7's.
The 12AY7 isn't overloading a 0.5W anode resistor. 0.25W would still have some margin. Higher power dissipation resistors are inherently lower noise so I suspect you're getting the benefit of that. I've used 2W metal films in mine, partly for that reason and also as they are higher voltage rated, 500V for the ones I'm using. Some of the lower power resistors are marginal for voltage rating, particularly for anode resistors at turn on when the valves aren't sucking any current.
The TAD is much quieter. Steady hiss level has dropped but also I was getting an intermittent 'frying bacon' sound on the Bright channel. It would appear that this was within that half of the JJ as it's failed to reoccur with the TAD.
Soundwise they're both JJ so not much I can say! I have however ordered a Harma 12AY7, given that it's a selected EH so hopefully also will perfom well for noise and lack of microhpony. I'll compare that with the TAD as and when it arrives.
Feedback
