Increasing caps for more bass - what size?
Hi. I'm planning on building a simple one knob bass overdrive, based on the following schematic from fuzzdog:
https://imgur.com/a/6XtHC
To make it more bass friendly I've read that I can increase the input and output capacitor sizes.
Can anyone recommend a good size to begin with to make this circuit bass-friendly? (ie for bass guitar through a bass amp, not just a bassy guitar pedal, if that makes sense).
Thanks.
  • Danny1969Danny1969 Frets: 10474
    The effect of the output cap size depends on the impedance of the load your going into, the formula to decide the -3dB slope is 1 over 2PiFC  .... You can find RC calculators to make the maths easier
    As a default I would use 100n for the input and 220n for the output because I always have those values and the RC value will be plenty low enough
  • ICBMICBM Frets: 72723
    Doubling the cap values will produce the same response an octave lower (half the frequency) than it has now, which gives the same values as what Danny suggested, so I would start there.
    But there's probably no harm in trying the largest ones you have to hand and which will fit on the board, if you like...
  • liamonliamon Frets: 103
    Thanks both, will give it a crack.
