Attenuator for a jcm800 - power brake ? Hot plate ??
riffpowersriffpowers Frets: 344
I reckon I'm gonna start looking for a 2nd hand attenuator for my jcm800.
Its been a long time since I looked at getting one , is the powerbrake or hotplate still the way to go or are there others to look out for ??
not looking to go to home levels , just want to be able to turn it past 3 at gigs without having to leave it in the car park outside .
  • ICBMICBM Frets: 72410
    Powerbrake yes, Hotplate definitely no.
    For a 2203, I don't think there is a better one than the Powerbrake, although I haven't tried some of the new options.
  • TimmyOTimmyO Frets: 7431
    On ICBM's (repeated) recommendations I got a Powerbrake to use with mine and it was good.
    I also used a Two Notes Torpedo Reload and that was even better - but not by that much and they are *expensive*
    I had to be a bit patient waiting for a Powerbrake to come up for sale but they are out there
    Red ones are better.
  • Thanks, powerbrake it is!!!
  • shaunmshaunm Frets: 1598
    I used a power break, worked well
  • Any idea how much I should expect to pay for one??
  • zepp76zepp76 Frets: 2534
    It's not cheap by any means but give the Rivera Rock Crusher a serious look, I use one with my JTM45 and it does a cracking job. There's no tone suck even when you switch to studio mode (to my ears anyway). It's switchable between 8 and 16 Ohms which is handy, it really is a great bit of kit. I'm sure there are other users on the forum who may be able to chip in on any info I may have left out.
    Tomorrow will be a good day.
  • John_AJohn_A Frets: 3775
    £120-£150 for a used powerbrake - Brilliant with Marshall's (as you would expect)  I would say that a JCM800 doesn't really need one unless you are planning using it at home.  The master volume is pretty good, and they only need to be on 2-3 to start sounding great.  'cranking it'  isn't always the best option
    Hi John, Thanks for the info. I agree, sadly about 2 is as much as I can hope to get out of mine with a decent 4x12 . Its immense!!
  • DanRDanR Frets: 1041
    What about the new two notes captor.
    I've just ordered one as a 20db reduction should be enough plus it has a built in cab emulation.
    I will be using mine with a Friedman Butterslax.
    I'm gonna guess that they're expensive
    Out of interest, what's so bad about the hot plate  over the power brake ?? I thought they were a well regarded bit of kit !
    The Hotplate has an odd impedance curve which differs very much from a real speaker - much lower, especially at high frequencies when the 'bright' switch is on. As a result it stresses the output valves heavily and can cause failures, as well as sounding not brilliant.
    There is a work-around - if you set the amp to half the impedance of the Hotplate - but it's still not ideal. The Powerbrake is much better because its impedance curve rises sharply with frequency - actually slightly more than a real speaker - but this is fine for Marshalls.
    The Hotplate is excellent with amps like BF/SF Fenders and Mesas, which prefer a low mismatch rather than a high one. It's not a bad bit of kit, just the wrong one for this amp.
    Thanks a lot . I learnt something there !!
    I suppose it depends on your idea of expensive.
    £199 From gear 4 music with free delivery.
    They had 2 16ohm versions in stock when I bought mine.
  • hywelghywelg Frets: 4303
    I've had (or tried) a Hotplate, DrZ Airbrake and Powerbrake.  Hotplate is great with Fenders crap with Marshalls and Vox style EL84's . DrZ worked OK  with Fenders and we'll with EL84's but not Marshalls.  Powerbrake was poor with Fenders but the best with Marshall as you'd expect.
    Oh, none of them work well below about 8dB of attenuation. Whisper quiet for bedroom use is pointless. Powerscaling works better for that, but even then that's not brilliant below about half power. A combination of attenuator, powerscaling and low efficiency speakers all used conservatively is the best option,  but for really quiet, modelling is probably the better bet.
    That's exactly what I found too.
    Surprisingly, I found you can get good sounds out of them even at very low settings provided you use them in a non-intuitive way - or at least the opposite of what you would think, and the attenuator makers tell you, of turning the amp up to get power-stage distortion.
    I found it worked far better to first set the attenuator to roughly the level you were likely to want, then dial the amp in for that level with the MV down low as well. Like that, I could get a Powerbrake to sound fairly decent with a 2203 on the lowest click (-30dB), with the gain up fairly high and the MV on about 1.5. EQ rather different from normal - bass full, middle nearly off, treble low, presence high if I remember right - and a big cabinet still sounded better than a smaller less efficient one. It's a lot of faff to get a tolerable tone at TV volume though.
    I don't like power scaling, I've never heard it sound as good as a decent master volume. I would maybe use it on an amp that doesn't have one, if there was no other option - but I still prefer the right attenuator.
  • Fryette Power Station.
    Daft expensive but one of the best bits of kit Ive ever purchased. Well worth the corn, and the F X loop is incredible.
    I wasn't thinking of using it for home use, I just wanted to be able to turn the amp up a little more in a live context as I find that I prefer the feel and response of the amp once you get over 3 on the master.
     Sounds like a win win to me, in this case I could flog my jcm1 combo and use my jcm800 all the time !!!
