I had one, you set the amp to be the lead volume, then dial it back with the pot to a lower volume, then you can switch between the two easily.
http://ews-us.com/item_volumeCtrl.php?item=custom
They are nothing of the sort attenuators work between the power amp and speaker section. All you would do is push the pre-amp gain and turn down the output - whereas the attenuator will allow you to push both the preamp and the poweramp stages and then reduce output to the speaker.
I use one in the loop of my DSL to floor the preamp vol and gain controls as much or as little as I want and set overall actual volume in the room with it. Without that extra volume control the same settings would be very very loud.
Unfortunately it can't be used to crank the power amp section (thanks for explaining that @ICBM ), you need a power attenuator for that.
While I was at it I also added a second pot to cut bass, but I haven't found that very useful, I think I need to experiment with different cap values.
The FX loop without it causes clipping of my pedals when the Master volume is high and so I used the volume pedal to slightly reduce the signal level coming from the FX Send to the pedals. Made a massive difference.
I now use the channel volumes on 'full' and the volume pedal as my master volume.
Sounds great and has made the Jetcity FX loop very useable.
I prefer this to using the Jetenuator as its less faff and allows the correct use of the loop.
Cheers
i scored this nifty little device for precisely this purpose.
https://imgur.com/a/BSww8
What a stupidly designed amp
In his thread on his gig experience with his Katana, @p90fool describes using a volume pedal very creatively which has me thinking, maybe that's the next step for this. A vol pedal would give total control on the fly instead of the set and forget nature of a pot in a box. Yeah, nice
