Carling DPDT latching - cheapest source?
£7.50 per switch from hotrox seems a bit steep, I was wondering if anyone knew somewhere selling them in low quantities for less.
On a similar note, does anyone know how these cheapy switches manage under heavy/long term use?
  • ICBMICBM Frets: 72411
    It's hard to get top-quality switches at any sensible price these days, that doesn't sound too bad. If you think it's expensive, check how much Allparts want for one! (Sit down first.)
    They break.
  • bbill335bbill335 Frets: 1379
    I've got one cheapy one left that I'm gonna use to TB a wah, then I guess I'll bite the bullet and order a handful of decent ones  :s
    Is there an in-between switch that's less expensive than the carling, but has a better reputation for durability?
    Alpha DPDT, but to be honest they are not perfectly reliable either.
    £7.50 is really not a lot for the confidence that it won't break.
  • Adam_MDAdam_MD Frets: 3420
    Definitely alpha I order them from rapid and it's about £19 for 10.
  • timhuliotimhulio Frets: 1286
    I really can't fault those Alpha DPDT switches. I use them in pretty much everything, and can count the switch failures on one hand.
