So, to you is it £500 better?
Is it ANY better?
I'm genuinely interested in the answers to the above questions BTW!
I tried a Katana 1x12 100, on clean, fairly recently at Andertons and my initial impression was that I preferred my Blues Cube and that the Katana clean was perhaps a bit more clinical and brittle. However, I've not had the opportunity to try the two amps side by side and in the same room so my perception might be flawed.
If I start gigging again I'd seriously consider getting a Katana as a back up amp, given the low price.
I suggest trying the two amps side by side.
But a couple of differences are the Blues Cube has an ply cab and a discrete analog power, whereas the Katanas are MDF with IC based amplifier stages. So that would account for some difference in cost, whether it transfers to a better sound I don't know. IME cab materal can make a big difference.
