String height reduction
Dunno if I've already asked this question before (I can't find it in my posting history) so please humour me.   Purely hypothetical situation so please feel free to offer geometric theorems. If a string is lowered at the saddle by, say, 2mm.........how much lower would the string be at the twelfth and first fret?
  • ICBMICBM Frets: 72352
    12th fret  - 1mm.
    1st fret - barely detectable.
    That is, assuming it isn't an acoustic, in which case lowering the saddle will most likely mean the top is being pulled up less hard, so you may get slightly more than a 1mm reduction at the 12th.
  • Thanks.......so the lowering at fret one wouldn't be by 0.5mm ?!
    No. It would be 0.5mm at the 5th fret.
    The actual reduction at the 1st fret would be 0.11mm, if you do the maths. The distance from the nut to the first fret is 5.6% of the scale length, so the height reduction at the 1st fret is 5.6% of the height reduction at the bridge.
  • FunkfingersFunkfingers Frets: 14430
    edited November 2017
    In Imperial measurements, the height reduction achieved at the first fret by lowering a bridge saddle would be described as "a gnat's".
    If you desire substantial reduction of the gap between the first fret and a tensioned string, the nut slots need attention.
