Maplin will have all the parts, although perhaps not a right-angled jack. You might have to make do with an over-cored cable from Maplin.
There are bound to be cable suppliers out there that do proper midi cable though.
Make sure the soldering iron gets hot though, and melts the solder quickly, as otherwise you'll end up melting the plastic holding the pins to the MIDI plug base, and have wonky pins. This is a real risk and can be a pain to put right - because you then need to heat the pin enough to melt the plastic again to push the pin back into alignment, at which point the solder melts and the wire comes off again. A merry jape, the first four times.
https://www.audiospares.com/product.php?productid=3083&cat=139&page=1
The Deltron stuff is ok
http://cpc.farnell.com/deltron/620-0510/din-plug-90deg-5p-240deg/dp/AV12826
I hate working on the cheap plastic ones.
An excellent cable for MIDI (and audio in general) is Belden V 9534. It is a network cable, foil shielded with a drain wire and 2 twisted pairs and very easy strip/solder. Overall diameter is only about 4mm so it is very flexible despite being a foil. You might as well connect all the pins.
Dins are fiddly so set a socket in a wee swivel vice to plug them into and use some silicone sleeving on each wire to prevent "whisker" shorts. The cord clamp is pretty crap on most DINs as well, I beef it up with a cm or so of heat shrink.
MIDI cable does not have an "impedance" as such so the cable type does not matter. I have sent MIDI down 40mtrs of unshielded CAT5 without problems.
Dave.
Yeah - depends who's paying, I used them at my former place of employment where cost didn't matter that much....They're easier to work with! Plastic din plugs are the work of satan. At least you only need 3 pins.
