Enlarging Tuner/Machine head holes?
What's the best way to enlarge vintage sized machine head holes, so I can fit modern machine heads?
I'm currently thinking, machine up a block of steel with appropriate hole spacing to create a drill guide, clamp it to headstock, then drill using a nice sharp drill bit. Tear out on the bottom side could be a problem, but would another block of solid wood clamped tight be enough to avoid any tear out?
Or is there another more suitable method, that doesn't involve too much expense?
  • FunkfingersFunkfingers Frets: 14456
    Never mind any of that. How are you going to keep the neck rock steady on the work bench?
  • munckeemunckee Frets: 12390
    I've seen people do it on youtube and they did it with a hand held tool called a reamer I think to avoid damaging the finish.
    edited November 2017
    Do yourself a favour and get a reamer, I did exactly what you describe on a new Allparts neck, the drill grabbed and split the headstock almost from end to end, the glued up split is now hidden behind a black painted face, bit is still just visible from the back and end, I initially thought I had ruined a £150 neck.......lesson learned......
  • ICBMICBM Frets: 72412
    The best way to avoid tear-out is to go from the back and *not* all the way through - only deep enough to take the tuner bushing. That way, the hole in the front is not enlarged - and can also be put back to the original collar size should you ever want to.
    I use a reamer to enlarge the hole until it's large enough at the surface, then a drill of the right diameter to open out what is then a conical hole to parallel. This also avoids chipping on the back.
  • SteveRobinsonSteveRobinson Frets: 7038
    I have a counterbore I found on eBay. The guide fits an 8.5mm hole and the cutter cuts 10mm concentrically, just deep enough for the collar of the tuner.
  • Swap the neck for one with preferred tuner holes. It can be a bugger of a job.
  • m_cm_c Frets: 1243
    Thanks for the suggestions guys.
    I think a tapered reamer followed by a drill as per @ICBM is probably a safer option, possibly with the neck suitably clamped in a vice to provide extra support to avoid it splitting. The last thing I want to do is split it, given how nice it looks!
    I'll wait until I get the tuners, so I can some proper measurements, as the Schaller technical drawing doesn't include any details for the securing fastener.
    That's very neat. I could have done with one of those in the past.
    To be honest I haven't needed to do this job for quite a long time though - the fashion for chunky sealed machineheads seems to have passed, more or less - so I'm not sure if it would save me a lot of work now...
  • FatPeteFatPete Frets: 683
    Or get a set of Hipshots - they do modern locking tuners that fit the vintage size holes
    Trading feedback: Trading feedback
