Not sure how to value this, how about £125 £75 posted inc P&P and assuming PPG which will cover the cost and having it removed and the guitar returned to factory wiring.Re Mike Christian from Long Island Guitar Repair
*If the name sounds familiar, you may remember a line of piezo pickups that I produced in the 1980’s. These revolutionary bridge saddle pickups generated uncanny acoustic guitar tones when installed on standard electric guitars and basses. These designs are currently used in Graph Tech’s GHOST line of pickups and are still considered to be the most authentic, natural-sounding electric guitar bridge saddle pickups available.
a PDF of the two page installation instructions which I'm posting here for future reference in case it should be helpful to someone else. The circuit is a dual channel buffer with both piezo and magnetic inputs, the two outputs go to a NM25KA dual blend pot to allow infinite mixing between the two systems.
Bigsby B50 Licensed Trem in chrome, in excellent condition except it's missing one of it's pins.
I was umming and ahhing about either replacing the pin with a bit of cut down allen key or removing the rest of the pins and drilling it to string through. In the end I've decided not to fit it to the guitar in question so it's now surplus.
Includes spring, screws and washers.
Does £25 posted assuming PPG sound reasonable? SOLD
