Strymon El Capistan vs Norwegian Airlines Baggage Attendant
ChrisCox1994ChrisCox1994 Frets: 368
So, after a nice gig in Norway my hold luggage, containing my pedals, was sent to another country, back to england and eventually couriered to my house.
Unfortunately the El Cap is damaged, mix knob ripped off and broken in two, thought it was fine, glued it back together and went to try it out, it now essentially has a kill dry function - permanently...
Any pedal experts know how easy it is to get a new mix knob for one of these and how easy it is to fit?
https://www.gbmusic.co.uk/
PA Hire and Event Management
  • TeetonetalTeetonetal Frets: 7816
    edited November 2017
    Why on earth would you put pedals in hold luggage? Having worked in travel... never do that.
    Edit: appreciate that's not a helpful post for you.. sorry.
  • Why on earth would you put pedals in hold luggage? Having worked in travel... never do that.
    we could only afford one hold + carry on and between my pedaltrain nano in a padded case inside a plastic case padded with clothes and my strat, I chose to take the strat onboard...
  • ok whos a pedal repair person I can send it to? I've worked out it probably needs a new mix and time knob...
  • I'd recommend posting it to Guitar aid in Putney if you have no one local. Probably a bitch to solder as all SMD.
  • ClarkyClarky Frets: 3261
    where did you play in Norway?
    I was there this weekend too
    https://www.strymon.net/faq/where-can-i-get-strymon-gear-serviced-outside-the-u-s/
    According to this, Strymon's distributor can service their gear. Might be worth asking a quote from them.
    MusicPsych Limited (Distributor)
    33 Ripplevale Grove, London, N1 1HS
    Tel: + 44-207-607-6005
    Email: support@musicpsych.com
    Website: www.musicpsych.com
  • impmannimpmann Frets: 12683
    They are good folks - they helped me out massively with the Hotone power supply issue I had. Deffo worth a contact.
  • GassageGassage Frets: 30952
    Fly with RyanAir next time- you get free delays with every trip.
    9reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    a small blues club in konsvinger, about an hour outside of Oslo
    cool..
    I was in Haugesund playing in a prog rock festival..
    indoor of course... lol..
    interestingly... when we changed flight in Oslo, I saw the baggage handler goon throw my rack
    and.. when I tried it out in the hotel that night it didn't work..
    I had to spend the night poking around inside the Axe-FX reseating the ribbon cables that had worked lose..
    got it all up and running in the end and had a great gig...
    I absolutely adore Norway...
