Website || Feedback Thread || PayPal
The other thing that will help is the 'Stokes mod', which means moving the supply to the phase inverter up one node on the power supply chain, which increases the clean headroom and tightens the overdrive up a bit.
I would also second richardhomer's suggestion of a neodymium speaker - the Jensen Tornado sounds really good in a Princeton so I expect it would in a Deluxe too, although I haven't tried it.
Some people may like the stock tranny, mushy bass is pat of the classic Princeton recipe.
I’ve found the Cannabis Rex to be the best balance for the amp so far -both in terms of clear, balanced voicing and consistent performance at different volumes. I guess those are the qualities I’d be looking for in a neo speaker - responsive, clear but not shrill. How would you say the Tornado fares? (I’ve also been reading up on Eminence Lil Texas which I gather is brighter, though seems to get generally good write ups)
The sound samples on the Jensen website are pretty accurate, I think. https://www.jensentone.com/jet_series/12_tornado_classic_100
Ta Jon
I guess the warnings are based on the assumption that the PI clipping is a limiting factor on the output of the amp, which may not be the case. And there certainly seem to be plenty of people who have carried out the mod without issues. I don't have a pressing need to tweak anything on that amp at the moment, but I might give the Stokes mod a shot next time I have the chassis out.
