Jumper Connection Tips?
When I have to make jumper connections between multiple lugs on a switch, for example, I've been using single core wire and twisting it through the lugs then soldering each lug.
It's quite fiddly and doesn't end up very neat though.
Any tips on how you make connections like that so in future I can do it more neatly and easily?
  • RolandRoland Frets: 8731
    Solder the wire flat on the lug, and use shrink tube over the top. It helps to secure and strengthen the joint, and also provides insulation.
  • ICBMICBM Frets: 72484
    Practice.
    That's exactly how I do it. I wouldn't do it any other way.
    Thanks guys.
    Just to clarify ICBM, say you had to connect 4 in a row, would you use one length of wire or 3 separate pieces?
    One, but I probably wouldn't feed it through the holes in the middle terminals - just the end ones. I would probably alternate from one side of the row to the other going past the middle two, if that makes sense - so it ends up as a wavy shape rather than straight. That will keep a firmer contact against the terminals. Obviously a moot point once the solder is on, but I don't like using solder to make a physical bond, it should be only to make a permanent electrical connection.
    Thanks again for the advice! :)
  • tampaxbootampaxboo Frets: 488
    edited November 2017
    if that isn't already one of RG Keen's 'Laws of stompbox building' it should be in the appendix.
    so many pedals (jack sockets, pots, stomp switches) fail because when movement or vibration causes the solder to loosen-flake off, wires can just float away if not anchored physically.
    i am the hired assassin... the specialist. i introduce myself to you... i'm a sadist.
  • SporkySporky Frets: 28483
    I've always done it with individual links - more repairable.
