It does reduce the volume, but not that much - and it sounds progressively worse as you turn down… unless you prefer a more middy, compressed tone in which case you might find it an improvement.
The magnet also sticks out a bit further than on most normal ceramic speakers, which could be an issue in some combos.
nice idea, but a good master volume worked better so I moved it on.
