I've been running an EL34 as the power tube in my Cornell Romany for a month or two now. It's a Winged C and I've really liked it versus the default 6L6 - smoother, more detailed mids. However, tonight noodling away the amp's started a dull, resonating rattle, particularly around certain low notes.
As it sounds a bit like long springs crashing around I though it might be the 'verb… or my missus rattling her chains down in the basement. But after doing the whole 'tap each tube with a pencil rubber test' there's no obvious microphonics. Swapped it for a 6L6 and the problem's gone. Is this a fatal mechanical fault with the EL34 or anyway to stop the rattle?
