I'd be more concerned that the bridge saddle appears to be far too high. If the action isn't, then something is wrong with the neck joint angle.
Looks like a few years (two or three) of accelerated growth - (water / sunlight) see how the annular lines get wider around the lighter colored area.
http://www.dropbox.com/s/n8mwn0yvl8hng91/IMG_2813.jpg?raw=1
I still think it's weird that those lines are visible when a week ago they were not..............
Whether that is too much depends partly on how deep the slot is. It's not a good idea to have more than half the saddle above the bridge, nor a good idea to have the break angle of the strings over it sharper than 45º - both of which look like it might be so, or at least very close, here - either of them puts excessive forward pressure on the saddle which at worst can break it, and at best tends to affect the tone since the saddle is being pushed forward more than downward. It also increases the 'turning' force on the bridge which can speed up the top bellying behind the bridge.
It may just be something to do with lighting. I think it's unlikely the rest of the top has darkened significantly in that time.
Mostly just to settle my OCD ;-)
For £250 I'm happy as it sounds and feels good.
https://www.dropbox.com/s/7ni699q8mi9sj2e/IMG_2839.jpg?raw=1
It looks borderline or too high to me, but if there's a bit of movement as the guitar settles down so it needs reducing at the next set-up it won't be as bad.
