FS: Palmer Power Pad 8ohm Atten
GassageGassage Frets: 30916
£139 shipped
Can run 2 8ohm outs on it.
Easily the best one I've used.
Boxed.
Specifications
  • Maximum input power: 120 watts
  • 6-position switch, 5 increments (3 dB each) for volume reduction, equivalent to attenuation of the input power to 70%, 50%, 35%, 25%, 18%.
  • The LOAD BOX position mutes the connected speaker cabinet.
  • The BYPASS/ATTENUATOR switch lets the user toggle quickly between full and reduced output.
  • Input from amplifier: 1 x 6.3 mm jack socket
  • Output for speaker cabinets: 2 x 6.3 mm jack sockets connected in parallel
  • Output impedance: 8 ohms
    How come you're selling it?
    Have you bought yourself a Helix and you're using the IRs straight into a DAW and headphones?
  • GassageGassage Frets: 30916
    I don't need it.
  • LebarqueLebarque Frets: 3863
    @Gassage ; Have you still got this?
    Nope. V good though.
    Bugger
