I'm putting in a stewmac order for a couple of bits, and thinking about some new tuners for my HD28. At the moment it's got chrome Grover Rotomatics, which are absolutely fine, but at the very least I'd switch to nickel.
Just wondering if anyone has switched from Rotos (or other heavy tuners) to something lightweight like a Sta-tite or Waverly, and what impact it had on tone. I like the idea of open backed for a bit of vintage vibe, but only if it won't change the tone for the worse.
I suspect it's a question of "it depends on the specific guitar" (and a hefty dose of "not broke, don't fix") but just thought i'd check in wth you lot...
So it's not exactly predictable and there may be an 'optimum weight', it's not simply that lighter tuners are better or vice versa.
But then I've never bought a guitar and sold it though I have given a couple away to younger players
who deserved a 'better' instrument.
I'm I missing out on all this 'fine tuning' ?.
Another interesting improvement I made to a guitar was to simply string it properly, using the same strings, when it had come in for "needs new tuners because it won't stay in tune". As well as then not needing new machineheads, someone on the other side of the shop immediately asked why it sounded so much better .
I find on bolt-ons I usually play about with shimming until it feels right to me, I think it also can afftect the attack of the note though not necessarily the general meat of the tone.
I simply strung it properly using the 'half back turn and lock under' method with the minimum wrap on the posts and tuned it up again, and it instantly sounded deep and clear like a Lowden should. I think the owner was a bit shocked as well… he'd "always done it like that" of course.
Obviously it's a slightly different thing than the mass of the machineheads, but it does make it very clear that the tone can be affected quite drastically by things that aren't in the 'sounding' part of the string.
