The spec is identical yes. There is a cheaper mahogany model which is designated with an M so watch out for that.
TBH go used, the old spec LS16 go for peanuts on eBay.
Thanks for the used tip, will take a look. How does the old spec differ?
When you look at the 6 series then the old spec is a better buy as it has an ebony board and bridge, whereas the new one has some sort of rosewood substitute.
Did you buy it used?
