The guitar is to my knowledge completely standard - no modifications.
The body is Alder, and it's finished in a hi-gloss candy apple red polyester. It has through body stringing via a vintage tremolo, with hardened, bent steel adjustable saddles.
Scale length is 25.5" and the maple neck has a 10" radius, with 24 high profile medium with frets.
Neck width is 41.3 mm at the nut, and the neck is finished with gunstock oil and wax blend to give a super smooth, non-stick finish.
Tuners are Schaller M6 locking items
Truss rod is adjustable, with no component or string removal required - there is a small black wheel at the body end of the neck into which you can insert an adjuster tool (and allen key, for example) and allows the wheel to be turned to make the neck adjustment.
Pickups are HSH with 2 DiMarzio Virtual PAF humbuckers and 1 DiMarzio custom single coil.
The pickup switching is as per the diagram below:
https://i.imgur.com/qx828ZU.jpg
great pics,
Well done, bloody good pics especially off a phone....I can't take a good pic to save my life with anything.
Lovely looking Silo, I've had 8 EBMMs (still have 5) but never seen a Silo in the flesh altho I hear the original Morse was based on one so guess they would feel very similar. Super guitars exceptionally well built. If I won the lottery I'll be back LOL GLWTS
I've done that myself on a few guitars by putting a connector in to make for easy swap outs but never realised the factory did it or offered it as an option even
This Silhouette would make the perfect Christmas present y'know.
