Hi all!!
After much deliberation I decided to keep my Yamaha TVL Semi, which has 3 P90s. However, if I’m keeping it, it needs some tweaking - currently the P90s are all super smooth, lack definition and the neck in particular is quite ‘dull’. Checked that there weren’t 250k pots and nope - 500ks all round!
It is my greatest wish that I never take the electronics out of a 335-style guitar again, so pretty much discounted swapping the pickups wholesale, but thought changing the A2 magnets might get me where I want without hassle and soldering!
Heres what I was thinking:
Neck - two A5s or an A5/A3 combo
Middle - A5/A3 or A5/A2 combo
Bridge - A5/A2 combo or maybe A5/A8 for more output
Is there any difference in which side the magnets go if it’s a combination? Am I goin to be over/unde powering any particular position with the above suggestions?? Any help appreciated!!
-Output depends on a combination of wind and magnet
Magnet differences in P90s are ore subtle than humbuckers.
I did some mag-swapping in P90s, most combo differences were fairly subtle but I instantly hated A5/A8 bridge, it was so sharp and.. just didn't like it at all. Didn't try it in the neck, praps it'd work there, and praps be fine with your pickups anyway. Cheap to try combos out though.
A8 with a vintage coil wind tends to sound nasty. It stands a better chance with a hotter wind. The Seymour Duncan Hot P-Rails is a case in point.
How far apart are the three P90s? I would try to avoid having an A8 in one pickup adjacent to an A2 or A3 on the nearer side of the next pickup along.
5/5 neck makes sense. 4/5 or 4/4 might also create the right blend of clarity and warmth without "mud".
5/2 or 5/3 for the centre position makes sense but, so would 5/5 or 4/5. Being closer to the bridge will bring some of the tonal change that you desire.
If the bridge position P90 is of approximately the same DC resistance as the other two, A8 magnets are unlikely to yield pleasing results. I would try sand cast Un-Oriented A5 (UOA5) or slim ceramic.
