Classic vibe Tele body - strip it or swap it?
I’ve got a off white Tele body - I hoped the pics were pale and it was more blonde but it’s more off an off white colour - vintage white?
Its nice enough but I’m not a fan - I nearly bought the blue Top Tele screlics recently did but probably want a see through butterscotch finish.
Any ideas how good the wood will be underneath and if it’s worth stripping and redoing or is the poly (I assume) a pain to get off and I should sell it and get something else?
  • FunkfingersFunkfingers Frets: 14426
    If the paint colour is your only objection, simply exchange your CV Tele for another in a preferred colour.
    A serious strip and refinish job could cost more than your entire guitar.
  • John_PJohn_P Frets: 2750
    It’s a body I bought for a project and I’d do the work myself do the cost isn’t an issue - just curious if anyone had stripped one to find its blockboard and needs a solid coat or a two piece that looked ok.
  • munckeemunckee Frets: 12356
    If its just the colour and not a nitro finish you are after you could rough up the poly and spray paint it.  I spray painted a squier standard strat surf green and it turned out fine. 3 coats of spray paint and 4 coats of spray on poly.
  • Adam_MDAdam_MD Frets: 3420
    I stripped and refinished mine a few years ago and the grain looked pretty nice when it was stained.  Unfortunately I'm going to have to redo it soon because the stain I used has faded badly in the sun.
    I sanded mine but I stripped a different body after that using a heat gun and it was much quicker.
    1reaction image LOL 3reaction image Wow! 0reaction image Wisdom
    John_P said:
    It's a body I bought for a project
    The simplest solution is to trade for a body of equal quality in the early Fifties custard yellow Blonde colour.
    Fender has applied the appellation Blonde to several, quite different shades of semi-transparent not-quite-white.
  • randellarandella Frets: 4168
    edited December 2017
    Poly does come off with a heat gun, it's not rocket science and I'm sure you'd be capable.
    I'm with @Funkfingers though, for the sake of the ballache I'd flog it and source a different one.
    Unless you fancy the project for the sake of summat to do with your time, in which case have at it.
    I can't remember if I said this to to someone else the other day - if you do strip it watch you don't nick the roundovers. You're after a semi natural finish so you don't want a load of car body epoxy showing through.
  • Sham61Sham61 Frets: 26
    I stripped a CV50 a few years ago with a blowtorch. Probably not the best idea but the poly was very thick. It softened it enough to scrap it off, I then sanded it with an orbital sander. The body was made of 4 pieces if I remember. I refinished with some Wudtone and a few coats of clear lacquer. Looked OK in a sort of punkish way.
  • ClashmanClashman Frets: 175
    Here's myTele Modern  Player  plus  in eye catching red..
    https://imgur.com/a/xKXug
    <blockquote class="imgur-embed-pub" lang="en" data-id="t7RsMEg"><a href="//imgur.com/t7RsMEg">View post on imgur.com</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
  • BigMonkaBigMonka Frets: 1770
    @Clashman ; here you go. And it looks great in red
    Thanks BM I  can't get this photo link thing right lol.
    I mixed drawing ink that cost £2 with  teak wood dye to get the dark rustic red.
    That looks nice.   Looks like the wood underneath is probably ok if I did go for a see through butterscotch.
    I was was thinking today I wouldn’t mind a gold top with faux binding but that will be a little more involved than a straight recolour.
