If the whole socket is loose then soldering it back on the board is the easiest option. I normally use a Weller hot air gun for 80% of the job and then .5mm long conical tip to solder the data pins
Worse case scenerio is socket has come loose and pulled tracks up from PCB, in which case it's still not impossible to do in most cases but it does make the job a lot harder.
I'm having a hernia op on the 5th of jan then I'm out of the game for a month, then on holiday for 2 weeks otherwise I would have done it for you.
