C18Q1 Bridgehouse's Tragedy Bass Rebuild - Abandoned
BridgehouseBridgehouse Frets: 24581
edited January 2018 in Making & Modding
I bought this a little while ago - a Yamaha RBX A2
It cost buttons.
It's comedy enough as it is - white top, battleship grey back and neck, passive, but a 9v battery to power the comedy volume and tone LED lights.
However, it has two things going for it:
- stupidly light. Must be 7lb ish
- pickups are decent and sound good.
So - I'm going to go for a rebuild. Why comedy? Cos it's painted in what appears to be spray on plastic UPVC window material - I suspect it will be an utter bitch to remove.
No more flashing LEDs so I will have to fill the holes somehow.
Apart from the fact its not a solid body and it will no doubt look shite when the crappy paint is off, it should be a doddle no?
It's stripped and ready for some action:
«134567
    Not so much comedy.
    Yamaha clearly coated it in some sort of powder.
    Random orbital sander and 15 minutes (!) and it came right off the neck..
    No more battleship grey for this..
  • FunkfingersFunkfingers Frets: 14496
    That explains a lot - including the white lines on the table cloth. =)
  • WezVWezV Frets: 16735
    edited January 2018
    they are solid.... solid balsa with a hardwood* veneer front and back.   The sides may dent very easily once stripped.   the bridge mounts from the back as the screws would pull right out the balsa core
    very light, very resonant and a bit different.  I applaud Yamaha for trying.... i don't think they were that far off with these, they just didn't sound that great
    *okay, balsa is technically a hardwood, a very soft and light hardwood.   the veneer is maple i think.
    Heh. Well I stripped it anyway.
    I figure once started..
    Bit more to do yet on the body but it's close.
    Did a bit of comedy reprofiling of the neck pocket as it stuck out a bit. Might have gone a bit far. Oops. Oh well at least it's even lighter now. I have no idea how much the paint weighted but it was a thick coat.
    Just weighed the body.
    1.14kg or 2lb 8oz approx.
    I may may well have to turn this into an ultralight build...
    Put most of the parts back on to check fitting and see where else I need to remove the remaining paint.
    Some more sanding to do and some more minor paint removal needed.
    Gave it a weigh in with most of the parts on and it's 6lb 1oz
  • TTonyTTony Frets: 27631
    That's looking quite good.
    Which prompts me to ask where's the comedy in "comedy bass rebuild"?
    Believe me - if you saw it when I got it you would think it was a comedy bass.
    Its the bass thats comedy, not necessarily the rebuild..
  • JezWyndJezWynd Frets: 6088
    Looks good, Danish Oil finish?
  • m_cm_c Frets: 1243
    And there was me thinking the comedy was the player..
    I think given the rather weak sandwich sides and the fact it's a bit ugly round there it will need a proper colour spray.
    I am tempted to do a car paint spray job just to see how bad they are..
    That goes without saying..
    Generally as bad as the person doing the prep and spraying..
    Probly about the same as my usual nitro efforts then ;)
    Either that or it's a stain finish, but I do want to protect those sides a bit!
    there is a reason it had a thick finish on it originally
    Indeed - shame it was pretty ugly.
    To be honest I don't mind a bit of natural relic ;)
    I coated a guitar version in copper leaf.   I just keyed the existing finish rather than totally strip... although its good to see the construction underneath here
    If I were you I would take this opportunity to inlay some wooden disks where the control holes are  - allow you to use normal controls rather than the recessed cups
    See if you can get someone to wind some new pickups too
    I was thinking about some wooden disks. I'm not sure I have anything to cut them with. I may be able to use a cutter I have as it will need to have a central hole for the pot shaft anyway.
    I might try the pickups again again and if not I might get them rewound.
    Still tempted to stain it and see what happens too
    In all seriousness, modern water based automotive paints are slightly harder to work with. The biggest problem is they run far easier, and take longer to cure, so as long as you're aware of that, they're not that bad to work with.
    And the only difference between gloss, satin, and matt finishes, are the thinners used. I needed some matt paint for a tractor bonnet a few years ago, and I was surprised to learn all it involved was using a different thinner when mixing the paint.
    How about gloss black sides, then something satin/opaque for top and back?
