To be honest. A bit of both. We do covers of Hendrix, Smashing Pumpkins, Bowie, Mott the Hoople, Steppenwolf, Kula Shaker, Radiohead, TRex, The Who, Pearl Jam etc
It's actually a good choice for people who want a 'set to stun' sound in the bridge position, if they never normally use the Strat bridge pickup. The only snag is that it compromises the second position sound as well, so if that's important to you, you may need to think about splitting it in that position. The good news is that with a single tone setup, half of the switch is not being used so you can have it auto-split in the second position.
Hot rails and others like them are some way short of conventional humbuckers and the bridge/middle sound would be lost.
That said, I don't like mixing pickup types on the same guitar. The fundamental character of the sound changes too much for me.
I also fitted a Floyd Rose and had a 22nd fret added
all this was to make it into a typical super-Strat with a HSS pup layout
as previously pointed out, the 2 pup selections involving the Hot Rail [bridge and bridge + middle] no longer sound anything like a Strat.. which for my needs is perfect..
interestingly, I actually prefer the 'bridge + middle' tone with the Hot Rail
it's not as pretty as the original tone and loses a some of that hollow / fragile quality
but it is superb for funk because it drives the amp a little harder and cuts through better whilst still being nice and bright..
I had a coil-tap fitted [via a push pull tone control] and despite this, that Gilmore 'bridge + middle' tone though is not the same..
it's a little thinner.. a coil-tapped humbucker will always be something less than a real single coil..
that don't worry me though.. it's not a tone I'd use for anything other than fun...
the Hot Rail is powerful, has good definition and I really like it a lot..
for my needs [rock / metal / prog rock / funk tones] it works brilliantly
if you really want that bright / spanky single coil tone typical of a Strat, a Hot Rail will be a mistake..
however, if you want a hot super-Strat, it's superb
what tone requirements are most used if this is to be a main guitar or most needed if this is filling a gap in your collection
or maybe a tapable output pickup? I'm sure I have seen some available from Oil City Pickups? @TheGuitarWeasel
1. Born to be Wild - Steppenwolf
2. The Bends - Radiohead
3. Ziggy Stardust - Bowie
4. Live Forever - Oasis
5. Children of the Revolution - T-Rex
6. Hush - Kula Shaker
7. Tonight Tonight - Smashing Pumpkins
8. My Hero - Foo Fighters
9. Sex on Fire - Kings of Leon
10. Stand Inside Your Love - Smashing Pumpkins
11. Jeremy - Pearl Jam
12. All the Young Dudes - Mott the Hoople
13. All Along the Watchtower - Jimi Hendrix
14. Love Reign O’er Me - The Who
