The main problem with both games in my opinion is the same as their main advantage. You're given a scrolling screen with the frets you need to hit as the song plays in real time. When you hit them correctly, the game 'learns' that you're progressing, and adds more notes. This is great because you're learning the song at full speed. However, it adds the extra notes at what appear to be random times, so you're expecting a certain level and suddenly another turns up out of the blue. If you're good enough to handle this, good on you, but I'm not, not all the time.
And if you're taken aback and don't adjust in real time, then just as you think you're getting used to it, the game drops you back a level and all of a sudden there are fewer notes on screen again.
Both games have no idea of how tab should be presented - they put the bottom string at the top of the screen, as if you're sitting at a mirror, whereas the tab sheets we're all used to have the top string at the top of the lines. I got almost universally shocking scores and some horrific sounds until I worked this out. You can change the orientation, which I have, but I'm surprised that they're still doing it the 'wrong' way to start with.
I much prefer the new version as the way the game reacts to your learning is much improved. It can still be a bit inconsistent about what it thinks are the right places for a note. I've quit in frustration a few times because there's a truly tiny window for what it considers to be an accurate hit.
The arcade games on the 2013 version are vastly superior, though - the new ones are designed to look like they were made in the late 70s and the graphics/soundtracks are almost universally appalling imo. :-)
It's definitely worth a crack though, cos there are quite a few songs worth learning, and even for a lot of the ones you don't think you want to learn, you wind up enjoying anyway.
