Dial in a good gainy sound and take the correct impedance speaker output of your amp with a speaker cable to the input of the talk box. Put the tube in your mouth having attached the tube to the side of a vocal mic with a couple of inches poking out to stick into your mouth while being close up to the mic grill. Connect the mic to a PA or a clean guitar amp and away you go. Move you mouth to change the vowel sound.
Marshall SL5 Slash Signature Combo for the guitar.
& for it I have a Orange Crush 30 R Combo.
and an MXR A/B splitter the guy sold me plugged into the mains via a power pack and enough instrument cables and speaker cables and a microphone & PA box (even)... but... So far no juice and I'm thinking you're right @MikkiMcMurderer and Jim Dunlop's UK distributor Westside conventionally on Denmark St / open on Sunday were wrong when they said 2 combo amps would be fine and didn't have any amps in store today to verify this for me.
I got money off the Jim Dunlop as I bought the only one/floor model (in the glass case unused) and they confessed people buy the MXR talk box because my one's a pain to work with.
Am I just missing the right amp type?
so guitar -> amp:
amp -> talk box -> guitar cab in
you then need to put the tube up to the mic and plug the mic into a separate amplification device eg: pa input.
so the sound will no longer come out of your guitar cab when the talkbox is in engaged, and will use the speaker on the talkbox to send the audio up the tube, you shape the sound with your mouth with the tube in it and the microphone from picks up the sound coming out of the tube and sends it to the PA.
do not drive the talkbox harder than 50w
the Dunlop Heli talkbox is a great great talkbox, but it is a proper one and needs a proper setup, you don't need an A/B splitter/switcher, you just need one amp with the talkbox between the amp and the same amp speaker, and a different amp for the microphone to pickup the talkbox output from the tube.
http://www.slashparadise.com/equipment/marshall-sl5-slash-handbook.pdf
you'll see 8ohm and 16ohm output. so you'd need to either disconnect the internal speaker and use the 8ohm output into the talkbox, then put the talkbox output (via a speaker cable) into another cab (it doesn't look like the SL5 has a jack socket to power connect the speaker looking at the manual, but I don't know as I don't have one).
The Orange will be fine, but you need to disconnect its speaker and connect the output to the input of the Talk Box. Then you can either use the switch on the Talk Box to turn the effect on and off (leaving the sound coming out of the main amp as well) or an A/B switcher in front of the two amps (the sound through the main amp stops when the Talk Box is in use).
So either:
Guitar > splitter > Marshall + Orange > Talk Box
Or:
Guitar > A/B switcher > Marshall + Orange > Talk Box
Then you will need a vocal mic and PA to reamplify the Talk Box effect.
That is massively useful to know, I count myself fortunate that I've always used this with a 2 amp setup to make the setup and volume levels easier to manage.
Thank you
