Ageing nickel parts with vinegar...
Is it as simple as putting the nickel bits in a little container of vinegar?
  • WezVWezV Frets: 16718
    No, it’s the fumes you want.
    get a bit lunchbox and pour half an inch of vinegar in the bottom.  Then float a smaller container on that, put the parts in this one.  Seal it all up.
    i prefer acid for chrome or etchant for nickel.  Not got the patience for vinegar
  • munckeemunckee Frets: 12390
    Do you need white vinegar specifically @WezV ; or is it just malt vinegar might smell bad?
  • poopotpoopot Frets: 9099
    ^this...
    if if you want to speed things up, go to your local diy shop (little one, not a b&q type) and get a bottle of “spirit of salts”... it’s hydrochloric acid.
    let the fumes do their work and check every 20mins or so.
    Does this process work on chrome parts, if not is there another DIY home process that does?
  • ricorico Frets: 1220
    edited January 2018
    I did as @WezV recommended and it worked a treat on some nickel pickguard screws. I think the vinegar was old though as it took about 6 hours for some pretty light corrosion.
    I will get a new bottle for the bridge plate.
    Here is a pic comparing before and after:
    Not a bad job I don't think.
    Chrome is pretty resistant to ageing.
    What happens is that the chrome layer wears away, usually in spots or flakes, and then the layer beneath the chrome plate ages. It's looks pitted rather than the more uniform 'grey' of aged nickel.
    You'll often see aged chrome parts with a shotblasted look, that's because they've tried to remove as much of the chrome as possible before ageing.
    You can sand away at the chrome layer and then age the piece (easier on small bits with a thin chrome layer). Be careful though: if you sand too hard you'll rip through the (nickel) layer beneath the chrome and reveal the plate below that, which is usually copper. If that happens, you can scuff of the copper to reach bare metal.
    Thanks I have sanded some chrome before and it looks like sanded chrome, I would like the dulled grey of nickel ratehr than aged exactly, I will give it a go.
    You could try the old trick of “tumbling” the chrome parts.
    put the part into a sealable container with a handful of screws of various sizes... then shake for a few minutes, check to see what the chrome looks like, repeat if needed.
    alternativly put the container in a tumble drier for a few minutes... again, check the progress and repeat if needed... if you use the tumble drier make sure the container won’t easily open, lots of little screws flying around a tumble dryer will break it!!!!
    once the chrome is “aged” to where you want it, then try the acid/vinegar/lemon juice fumes.
    below is a chrome plate I did in the tumble dryer.
    http://a67.tinypic.com/2qu12d0.jpg
    You have to damage the chrome in some way so that the underneath layer (nickel plate) is partially exposed - or at least that's what I surmise. Sanding screws or a pickguard bracket is easy enough, but something large like a control plate has to be done randomly and using different grades or it'll look, well, sanded.
    @poopot that is a belting job!
    Ta.
    just to add... be very careful if using acid fumes to age chrome... I once did a chrome trem (cheap for experimental purposes) every time I looked in the container there was no patina what so ever... so I left it a bit longer... and a bit longer... and longer still.
    what actually happened was the acid ate away at the metal under the chrome (found a way in somehow) and left the chrome intact!...
    i ended up with a hollow chrome chrome trem that just crumbled as I picked it up!,..
    Ta.
    That is a belting job.  Will give it a whirl, I will experiment with my tuners as I want to replace them anyway.
    Ta.
    Dear lord!
  • SpringywheelSpringywheel Frets: 942
    edited August 2023
    Does anyone know if vinegar works on zinc alloy?
  • FunkfingersFunkfingers Frets: 14455
    edited August 2023
    Stronger solutions of acid will eat away zinc.
    STUCK RECORD TIME
    The usual sequence for electroplated finishes is copper, nickel, chrome.
    Carefully monitored imersion in diluted Spirit Of Salts will gently dissolve away chrome to expose the nickel beneath.
