If you are planning on doing that with a simple Y cable then it won't actually change the output voltage, which will remain at 18V on both outputs. It simply means you can plug 2 18V pedals into the same socket, and draw more current from it.
I'm not sure if there is a proper step-down splitter cable that can do the job, but I'm not a pedal expert.
However, the same simple Y splitter cable plugged into one of your 9V outlets WILL give you what you need, as long as the combined current draw of both pedals do not exceed the maximum limit of your single 9V output.
A 9 volt one watt zener in each 'leg' would take the voltage down to 9V and handle about 100mA.
Dave.
The only potential downside is that the pedals sharing an outlet won't be isolated from each other, which *can* mean noise. You won't know until you try. Keep digital and analogue separate and you should be golden.
Thanks for your reply. The only pedals I'm looking to power using a single 9v (100mA) outlet is the Keeley Compressor Pro (50mA) and the Barber Gain Changer (12mA). Do you foresee any noise issues in this case?
Thank you!
Thank you!
