In fact, there never has been any standardisation of voltages - the UK is still 240V and Europe is still 220, but there was a classic Euro-fudge in how they were defined so they both appear to be 230 give or take a bit more than before depending on where you are .
So the voltage 'over there' is a little lower. Which is better than the other way round! I'd be more careful about using European amps here, even though in theory they should still be safe at the maximum UK voltage.
Check your amps though - some have selectors. Just don't forget to put them back when you get home!
