Good luck with the project!
i look forward to your ‘project’ thread
Electrics, I don't have a scooby!!
Might have to buy a soldering iron and give it a bash...
Any advice on decents pots etc?
Grover tuners.
Faber Bridge parts.
Oil City or Mojo pickups.
CTS pots.
Switchcraft switch and jack
First job would be the mechnical parts to make sure it can be setup to play well.
then I'd be searching ebay and the classifieds here for second hand electrics.
Don't worry about doing loads of soldering practice. The most expensive thing you could damage is a pot (assuming you don't do anything mental)
Faber-Castell would be cool - just spotted a cheap bridge and stoptail from a secondhand Gibson Explorer on ebay, which could be a good start.
But then, do you go totally different - War Pigs!!
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
Good suggestion.
I'd use a guitar like that to host Oil City Winterizer II humbuckers. (All the fun of the Firebird without the inconvenience of a vulnerable headstock.) Volume control per pickup. Switchcraft angled selector switch. Master tone control. Decent gap between the pots and the jack socket.
Get sliding.
Nearly bought it, as it had the original pups with it and tuners - but it was white and I wanted red :-)
Good advice on pre-soldered loom.
Joking. Good luck with it. I couldn't solder for toffee, but bought a decent (correct wattage) iron on Amazon, with all the bits, watched some Youtube tips and went for it. Am now quite happy swapping pickups in and out etc!
Ive done a bit of soldering but need to practise as the solder generally falls off!!!
Got my eye on some original hardware and tuners but time will tell.
Now starting to look at which Pot to use - yes, I know!
2 vol, 1 tone, 3 way and the input.
So,
Linear v Audio - Any advice great fully received!??
500k v. 250k - 500k seems right for an SG.
0.22 cap? - Seems Standard
Spent the last few weeks pulling parts together and here it is, after about an hour, fully fitted..
SG https://imgur.com/a/PkiKY
School boy error, no strings in the house - so a job for tomorrow and I'll have a play around with the set up and see if the nut is OK.
The job I have and haven't been looking forward to - wiring.
All parts in place and cut the wires.
Soldering iron out and guess what...
The solder just kept falling off. Lol.
Off to YouTube for some lessons and I'll crack on again tomorrow.
Here's a nice wiring picture if working to.
2 vol, 1 tone...
https://imgur.com/a/smXJ4
