Fender Strats and the wabbly/clicky trem arm, are customs any better?
Im on the hunt for an awesome Fender Strat, but one of my main gripes about my old one was the click I used to get when I started to use the trem bar/vibrato bar/whatever you call it. It also never felt as snug as my Suhr or PRS does.
So the idea was that I buy one and fit a Callaham as they’ve got good rep for feeling sturdy, but now I’m thinking that the specs I want may warrant a Custom Shop build, so my question is...are the custom shop bridges any better than those you get on a standard strat? Are they any more sturdy and are they nicer feeling? I’m hoping so!
  • simonksimonk Frets: 1467
    edited February 2018
    Nope. You can use wood glue or PTFE tape as a fix though.
    You may get a better block in a CS instrument, they all, as far as I’ve come across, suffer from wobbly arm syndrome though.
  • Get a steel tremolo block with a nylon insert. That stops any movement, depending on how tight you screw it in.
  • sweepysweepy Frets: 4184
    If it’s a solid block pick up one of those handy spring inserts, stops the slop completely
  • tone1tone1 Frets: 5164
    I PTFE Mine... works a treat   :)
  • Bloody 'ell, wish I'd talked to you lot before jumping the gun and selling mine last year. That said, at least I know what I want from a new instrument now and hopefully I can find something that suits me better!
    Thanks all for the input. Looks like a CS strat may be the way to go and those spring things or tape could well be the fix! :-)
    CS Strats come with the arm slop spring in the pocket with the spare trem springs
    Back in the day they used to be fitted with a coloured sticker over the hole to stop them falling out when the guitars were hung up in shops
  • I remember my strat having a green sticker on the bridge! So that's weird. Interesting!
  • RandallFlaggRandallFlagg Frets: 13941
    As mentioned above, the CS Strats I've owned have all had been a bit clicky with the little spring inserted. PTFE tape on the trem arm tread is a better solution but I screw the bastard trem down and tighten it with all 5 springs on board. Don't click no more!
    I’ve never found the tiny spring very effective at eliminating arm wobble.
  • I put a Callaham block and the matching arm on a US lonestar and it was no trouble after that.
