Can anyone recommend a guitar tech in surrey/hampshire/london that are good with offsets
My jazzmaster has become really hard work, i'm hoping a professional set up and fret dress might do the trick. Can anyone recommend a place that has experience with these guitars?
(I know any tech should be fine in theory, i've just had bad experience in the past with people refusing to even work with it, or it coming back with a worse set up than when I gave it to them, hopefully they are so common now its not an issue any more)
  • poopotpoopot Frets: 9099
    Charlie chandler in Hampton wick...
  • FuengiFuengi Frets: 2850
    Simon Jones in Portsmouth is a master.
    http://www.sglguitars.co.uk/ ;
  • ColsCols Frets: 7112
    Richmond Guitar Workshop, run by the two Andys formerly of Chandlers.  They did an absolutely fantastic job on my Les Paul.
    http://www.richmondguitarworkshop.com/
  • FelineGuitarsFelineGuitars Frets: 11637
    We know our way around Jags and Jazzmasters etc very well
  • winter_reverbwinter_reverb Frets: 39
    edited February 2018
    cool thanks, croydon is do-able. The problem i'm having with it is that it has extremely poor sustain (even by jazzmaster standards) on higher frets, i'm hoping a full set up and fret dress might do the trick, how much would that cost? thanks
    Charlie has worked on a couple of Jaguars for me and was fantastic. One was borderline unplayable and he turned it into a 100% reliable gigging workhorse. Call him!
  • thanks for the replies everyone
    Fret dress would cost you £120 but I would want to look to see also if the break angles over the bridge and nut are sufficient, it’s a common issue with jags and jazz masters . Sometimes a change of neck angle in the body pocket can assist an improved break angle and sustain with it.
    some players resort to the buzz stop roller which can have a similar effect. That not withstanding a fret dress may be of great benefit.
  • Thanks, I shimmed the neck myself but it would be good for a professional to take a look at the neck angle, I will email you
  • BrizeBrize Frets: 5635
    I can highly recommend @FelineGuitars - their set-up work is exceptional.
  • What bridge have you got on it @winter_reverb ?
  • A staytrem
  • 57Deluxe57Deluxe Frets: 7345
    good with offsets? - you mean wears a made up shoe or has one ball bigger than another??
    <Vintage BOSS Upgrades>
