Bear in mind that the screw hole position doesn't correspond to any of the 'right' Gibson tuners and so you can't later swap without it showing, if that is ever likely to matter.
http://www.hotroxuk.com/grover-102nk-original-rotomatic-3-a-side-tuners-in-nickel.html
