Following on from my IEM thread (Thanks for the responses BTW - got the LD 1000 set with some ZST earphones), my three-piece band are trying to figure out how we can now get three separate monitor mixes.... when the desk only has 2 aux out (these are the monitor outs).
We're using a Mackie CFX12 MK2 desk, and we each use in ears now. The desk has 2 aux out sends, with each channel being adjustable through these aux outs.
My guitar is via a Fractal AX8, using 2 cabs as backline, but I have a feed into the desk (with the FoH volume down on this channel) so that we can get it in monitor. Bass is also the same, but DI output into it's own channel.
It has something called 'SUB out' which seems to allow you to assign each channel to sub group 1-2 or 3-4.... which would be OK, but it only comes through if the channel slider is raised (which we don't want for guitar and bass!).
So, in a nutshell - is there a way to get 3 seperate 'monitor' outputs from this? Or anything else we should do that would be better?
There are other ways to use the inserts and another small mixer to achieve seperate mixes but it the real anwser is to get something modern and digital but cheapish like an X18, DL1608 etc .... digital mixers come with more aux sends and IEM mix control via your phone
No offence but it does make to smile when a band has got 2K worth of guitar backline and £200 worth of mixer
Was just looking at the DL806 actually.....!
