Hand Wired Bluesbreaker Vs PCB
ChaosJunky135ChaosJunky135 Frets: 11
edited March 2018 in Amps
To put it simply i have been asked to join my friends band as his guitarist ditched them at the last gig they played, they are mainly rock and blues and play some quite big venues but being the metal head i am im not sure my 100w ENGL will quite work for their sound haha.
Looking at picking up a Marshall 1962 Bluesbreaker and was just wondering if anyone has had the opportunity to play both the hand wired and the pcb and in you opinion is the Hand wired worth splashing out the extra £1000 for?
Thanks in Advance
  • soma1975soma1975 Frets: 6691
    It’s more expensive so it will be better
  • robinbowesrobinbowes Frets: 3042
    Personally, I'd save your money and get something cheaper/more manageable/ligher/more portable.
  • longjawlongjaw Frets: 423
    This - get something like a JTM-45 head and Zilla 2 x 12 cab.
  • hywelghywelg Frets: 4303
    edited March 2018
    Me, I'd go for a 1987/6. Bit more versatile,  tighter bass. And don't be wedded to Marshall. Plenty of decent clones out there.
    Indeed give @martinw , MJW amps a shout and talk about a superbass/lead with powerscaling .
    My dream is to have a setup like Marc Ford's Satellite. A JTM 45 1x12 combo with 1x12" extension. But for under £1,000 and with power scaling :)
  • PlectrumPlectrum Frets: 494
    Try the Marshall Origins when they come out. A bit more Plexi than JTM45 but still very vintage sounding.
    One day I'm going to make a guitar out of butter to experience just how well it actually plays.
  • Thanks for the info guys, size isn't really the issue as I run a 100w head and 4x12 at the moment anyway. Was just wondering would the PCB hold up to being cranked for most of its life like a hand wired haha
    I have been looking around for someone who makes clones but have really fallen for the pure size and looks of an original
  • jpfampsjpfamps Frets: 2734
    I've worked on tons of 60s and 70s Marshalls.
    From memory I can't think of any repairs I've had to do because the amp was made made with a PCB rather than tirret board.
    Yep they are on my radar for sure.
  • ICBMICBM Frets: 72339
    Me neither. In fact, the later JMP PCB Marshalls are extremely well-made and reliable in general, with the exception of the appalling pull/fall-out voltage and impedance selectors, which were finally changed near the end of the series. The PCB is done exactly correctly - with no large, heavy or heat-generating components mounted on it (apart from a couple of resistors, but they're well-spaced off the board) and with flying leads connecting the pots and jacks so no stress is transferred to the board.
    The reissues are built in the same way, and with better quality selectors. I haven't worked on a hand-wired Bluesbreaker reissue, but I can't see any inherent reason they would be any more reliable.
  • TTBZTTBZ Frets: 2897
    I'd rather move a 100w head and 4x12 around than a bluesbreaker, they're heavy old buggers and awkward to carry.
    The Origin will probably work well for you and save a load of money, they're great amps :)
    Why would the Engl not do the job? I'd be thinking, better to use gear I'm really familiar with than something I'm not, and finding out on the gig it doesn't do .... I saw a 9 piece reggae band a while ago, guitarist played through a 100w TSL and 4x12 in a small place, sounded great :)
  • p90foolp90fool Frets: 31590
    I was thinking the same, I used a JCA100HDM for country blues for two years, it was excellent.
    I used a Mesa DC-5 with a 50s rock'n'roll band too. 'Pushed' clean channel, sounded excellent... but did look pretty wrong on stage - although no worse than the bass player's Peavey.
    Punters don't notice or care though.
  • simonksimonk Frets: 1467
    I used an Engl Powerball and Marshall 2x12 in a Blues Brothers tribute band... all kinds of wrong!
