I do actually already have an S1 but the reason for moving away from it is mostly that they seem to be unreliable (mine broke but Normula from this forum helped me fix it - I would rather avoid having to take the guitar apart every now and then to fix it, if it even remains fixable in the future).
There's the other thing that my guitar will have a 500K volume pot and my S1 is 250K. I will be having one 250K tone pot but then my tone pot will say volume! Fairly trivial, I know. It probably wouldn't be a deal breaker if it wasn't for the fact that I believe the S1 switches are unreliable. It's a real shame because it's such a beautifully neat concept.
Alternatively use a Dremel mounted on a plunge routing base, with a down cut (inlay) bit or similar. If you set up a straight edge as a fence you should be able to rout a small straight slot for the toggle. I haven't done it for a toggle myself, but have routed for a 5-way lever switch and the principal is the same.
http://www.thefretboard.co.uk/discussion/89942/caspercaster#latest
Looking at the picture of Gilmours guitar it seems the toggle slot is wider than necessary, so perhaps that is how it was achieved on his guitar? Actually, looking at the lumpy fill behind the bridge and the poorly fitting pickguard around the neck joint make me feel a lot better about the standard of my own repairs/ bodges!
I could consider getting a Dremel but definitely not a "plunge routing base" I'm afraid, I'll have to go with your drill + needle file method.
I had read of quite a lot of people having them fail on them so was sceptical buying it but did so with the intention of going to this Gilmour mod if it turns out to be as unreliable as I feared.
The problem was solved by squeezing the tabs that hold the pot to the chassis with pliers. I imagine it might be the constant pressing of the switch down the middle of the pot shaft that might cause it to push the pot apart. Just a guess.
If I hadn't read of all the other problems with it, I'd give it another chance but with all the reports of its unreliability then mine failing after 3 months, not sure it's worth the hassle.
With the correct template, a drill could perform the entire cut in moments. Unfortunately, it would take more effort to make the template than to do the work on the pickguard.
Any tips on doing it without a template? Just use a needle file to connect the drilled holes?
An oxy-acetylene torch, followed by the burr, might prove a tad excessive.
I'm going to try it out on a spare pickguard just to try the switch out then I'll order a custom one if I like it - would end up cheaper than any of the tools required.
Nomad
What does that have to do with cutting little slots in thin plastic sheet?
Nomad
I'd be more likely to consider a push-push pot but CTS don't make them at all.
It's such a shame that the S1 is so problematic, I love the concept of it so much and when it works it's great.
Nomad
This bracket is attached with the volume and middle tone knob then the mini-switch is mounted on the recessed part so it's about an inch below the pickguard and only the tip of the switch pokes through.
It's mostly just for aesthetics; it does look quite cool when the hole is precisely just big enough to allow the travel of the switch.
I made a bit of a pig's ear of my test pickguard to be honest lol
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
