Small board options.
John_PJohn_P Frets: 2750
I’ve just started working with a bluesy rock band so as I don’t need as many options as I get from my ax8 rig I thought I should get around to making a small board and use some existing pedals.
I have a KoT and a DM2 at the moment and I was thinking about a pt nano+ but I would probably get more use from something a little bigger so I’ve set a pt metro 24 as the maximum size.
https://i.imgur.com/Yr2tHYs.png
OR
https://i.imgur.com/VNPfLoZ.png
I’d appreciate any thoughts - particularly with the drives if I’m missing an obvious choice.
 I’d like to add a low gain I can leave on most of the time - broadcast would be cool but takes up a lot of space so perhaps jan ray or Timmy type pedal and something Marshally that sings for leads - maybe a Friedman be or something with a little less gain.
A second delay so i can switch between slapback and longer so I was thinking el cap or an echoplex and then a flint for tremolo with bonus reverb.
