How to get satin or raw wood feel on neck?
LebarqueLebarque Frets: 3866
I'm just about to embark on a new Partscaster. As usual, I'll go for a nitro finish body, but I've recently got into raw wood feel necks, or the satin that Fender do. Nothing too shiny and with a lovely slippery feel. How can I achieve this on my maple/rosewood? neck Nitro always feels sticky and glossy. NB. I still want vintage tint. Thanks in advance.
  • hotpickupshotpickups Frets: 1822
    Do you mean like the musicman necks too etc?
  • FezFez Frets: 522
    I used wire wool on a lacquered strat neck which worked well, just required some elbow grease. I think you can also use Scotchbright abrasive pads.
    Don't touch that dial.
    @GSPBASSES gave me some great oil that will do what you want. I'm not sure what it's called but I imagine he can fill in that blank
  • WezVWezV Frets: 16676
    There are many ways to get there but any kind of oil and/or wax blend with lots of rubbing and buffing will work
    my favourite for raw wood is wetsanded tru-oil followed by briwax applied with 0000 wire wool and s hell of a lot of buffing with a soft cloth.
    my favourite with lacquered wood is micromesh
    edited April 2018
    I find a couple of coats of tru oil works really well and I do mean a couple...you could stain it first.......
  • LebarqueLebarque Frets: 3866
    Some good ideas thanks, chaps.
    @WezV - if using Micromesh on lacquer, do you keep rubbing until you get to the wood?
    @hotpickups - Not sure. Not played one.
    @meltedbuzzbox - Graham's made the body and neck for me, so I'll ask! Cheers
  • CasperCasterCasperCaster Frets: 761
    edited April 2018
    Graham has previously recommended Morrells Eze-oil. If you search the forum there are many threads on oil based finishing with Gunstock oil, Crimson finishing oil, Danish oil and the like, including this thread where Graham describes Eze-oil:
    http://www.thefretboard.co.uk/discussion/76402/wudtone-black-magic-woman-finish-any-experience/p1
    The Eze-oil isn't at all easy to get hold of,  and is expensive (over £30 for a little can), and has a limited shelf life once opened.
    Nope, you can rebuff a lacquered neck with micromesh and it will feel significantly less sticky.  You can even still have it glossy.
  • Check the Music Man forums for lots of threads on oiling and waxing. It’s dead simple though. Wipe tru-oil over the neck with a paper towel, then immediately wipe off with clean paper towel. Repeat with gunstock wax.
    You’re done. It’s a two-minute job, and the result looks and feels amazing.
    Agreed!
  • crunchmancrunchman Frets: 11448
    Just put a couple of hundred hours of playing on a normal nitro finished neck.  The sticky feeling will be gone, and it will be lovely.
    Agreed!
    Agree to a point.   Spending more than 2 minutes will give a sleeker feel and need less maintenance.
    most raw wood is not sanded past 240g.  You are only ever going to get that so smooth.  Sanding up to 1500g before starting the process, or wetsanding with oil between the first coat of oil and the final wax will take more effort but reward you with a neck that will make a music man feel rough by comparison
