Hello. At home I run a few amps, a couple of 'wall wart' PSUs for individual pedals and a brick for multiple 9vdc pedals. When plugging straight into an amp, nice and silent. When I go via any pedal I get a hum, which I assume to be mains hum. Doesn't matter whether I'm using the brick PSU, or one of the dedicated PSUs, or going via an extension cable or straight into a mains socket, always the same hum (hence my assumption it's mains and not anything to do with my PSUs/pedals). So 2 questions:
1. Why don't I get the same hum when going direct to amp? Is it something to do with the transformers in the PSUs? Is it actually 'transformer hum' I'm hearing? (If there's such a thing!)
2. What to do about it? I'm thinking of 2 things....first something like the Furman M-10 LX E for powering things which take IEC connections - amps, monitors, i/o interface etc. Second, is there an equivalent of the Furman in an extension lead format? I'm thinking a 'silent' extension cable to plug the brick and my PSUs back into - or in this scenario would I be back to 'transformer hum'?
Also looking at a new brick as I'm conscious the outputs on mine aren't isolated. That said, I get the same amount of hum with just 1 pedal as I do 6, so I think that's mains again, as opposed to interference between devices.
Any advice greatly appreciated!
Since the 'Mains Supply' is common to all states of the gear it follows that it is not the cause of the hum!
UK mains is very stable, very clean and not prone to 'spikes'. You do NOT need any filters or conditioners on it. IF you have crap on a mains supply it is the DEVICE PRODUCING IT that needs filtering (ever seen the BMthr filters in a MW oven supply?) .
You could have an earth loop, (aka, ground and hum loop) . You might be using more gain than direct into the amp. One common problem is that external 'line lump' PSUs themselves tend to radiate hum quite badly, keep them a mtr away from sensitive kit and leads.
It is a fact of electric guitar life that the things are noisy bstds, prone to picking up hum and other radiated crap. The more gain and gear you put in the signal path, the worse it gets.
Dave.
Nil Satis Nisi Optimum
Earth/ground/hum loop - how does one address that?
It does, yes. Just but a battery in a Boss pedal, works fine and nice and quiet - soon as you plug the PSU in the buzz is immediate.
Some digital pedals are extremely picky about power supply too.
I said maybe.....
But, if I power the reverb (or another other 9vdc centre -ve box) from my power brick, I also get the same buzz. I also have an OD which runs its own 12vdc and it too is silent.
So could it be both my wall wart 9vdc and brick PSUs are buzzy things which I should swap out? The fact my delay and OD run silently on their own PSUs, plus silence when guitar direct to amp, confirms mains is fine and it's the PSU end where problems lay - that be right?
Cheers!
Power bricks and daisy chains and so on can work great, but in some scenarios they'll give you noise. I lived with a daisy chained one spot for years without any problems at all, then I moved house and discovered hideous noise issues. Isolated supply fixed them.
It's tricky because a hum loop is formed when two pieces of kit have two 'earth' paths. In the simplest scenario, pedal A feeds signal hot and cold, earth, to pedal B and hence to G amp (which is earthed?) PSU feed 9V (say) DC and the earth is common to both pedals. If each 9V output was completely isolated there should not be a problem but since guitar forums are awash with these problems, clearly it ain't necessarily so!
Said it before, Twere I, I would make up external packs using AA cells, per pedal.
Dave.
https://www.andertons.co.uk/guitar-dept/electric-guitar-accessories/pedal-power-supplies/strymon-zuma-effect-pedal-power-supply
This will power my 9 and 12vdc pedals, all isolated. For the one pedal I have which is centre +ve, I'll use something like this:
https://www.andertons.co.uk/guitar-dept/electric-guitar-accessories/pedal-power-supplies/t-rex-polarity-inverter-cable-orange
That all sound about right?
https://www.andertons.co.uk/bass-dept/bass-guitar-strings-accessories/pedal-power-supplies/truetone-1-spot-pro-cs7-power-brick
https://www.andertons.co.uk/guitar-dept/electric-guitar-accessories/pedal-power-supplies/decibel-eleven-hot-stone-smd-multi-pedal-power-supply
https://www.musicstore.de/en_GB/GBP/Voodoo-Lab-Pedal-Power-Mondo-/art-GIT0026231-000?campaign=GShopping/UK&gclid=EAIaIQobChMIts7TrLLI2gIVDCjTCh20rwAnEAYYAyABEgLLsvD_BwE
