Recently picked up a Squire Tele with single coils. My first venture away from humbuckers. So this maybe a stupid post but I no no.
I noticed when I plugged it in, its quiet compared to every other guitar I own, which are all humbucker equipped.
When I switch to a gainy channel its less noticeable, but the difference between a humbucker guitar on the clean channel vs the squire with its single coils is pretty noticeable!
I then wondered why is it a lot more noticeable/quieter on just the clean channels? I can turn the amp volume up obviously to compensate, but then the gainy channel is too loud when kicked in. Would have thought the gain channels would have been quieter too just like the cleans..
Any info welcome!
It will be more noticeable with a clean sound because overdrive/distortion acts as a sort of compressor/limiter and tends to even out volume differences.
A P90 is closer in output to a humbucker than a Fender-type single coil even though it is actually a single coil, because it has more windings - which is also why it has a fatter tone. It will sound clearer than a humbucker though.
You can also get higher-wound Fender-type pickups if you want more output volume, along with also a fuller tone.
I prefer lower output pickups. They give you a lot more control on that edge of breakup kind of sound. With a good amp you can hit the strings softly and it will sound clean, but hit them hard and it will sound driven. With high output pickups they just seem to drive the amp all the time.
Higher output pickups generally sound muddy as well - more mid-range and not as much detail.
You can always add more gain, or a boost, to low output pickups.
Eqd Speaker Cranker clone
Every days a school day. I presumed single coils being single would be the culprit, but it was just an unexpected thing!
