This is it. Peavey Hartley Peavey signature EXP.
Sorry. The mobile text editor is giving me problems.
Band Stuff: https://navigationofficial.bandcamp.com/album/silhouette-ep
https://store.duesenberg.de/en/hardware/tremolos/34/duesenberg-les-trem-ii
I guess I'm looking for something that will replace the saddle piece and allow for vibrato movement. But I'm not sure such a product exists..
Thanks for the suggestions guys.
Sorry. Editor issue.
Er - short of routing it, then, I can't see a way. Sorry!
https://m.thomann.de/gb/schaller_tremolo_scdc_c.htm?gclid=CjwKCAjwiPbWBRBtEiwAJakcpEuXC-jecb_szaDLBzTArQ4-9IXlbQXN-wSmvOAEtsgyXOTxHDc8lxoCiMYQAvD_BwE
http://www.fairdealmusic.co.uk/media/catalog/product/cache/1/image/1ad2536b4e0b64b5213084f52c752e7f/v/b/vb-2w_f.jpg
or
2. Buy another guitar that has a Trem...
Both involve acquiring gear, which will make you smile
https://schaller.info/en/tremolos/363/les-paul-tremolo?c=51
It's intended for a Les Paul, but for some bizarre reason that I've never understood, it's designed to fit on the *bridge* mounting points and not on the tailpiece ones. This is very odd as it leaves the tailpiece studs unused, and usually the bridge mounting points wouldn't be as strong since even on a Nashville-type bridge, the inserts in the body are a smaller diameter than the tailpiece ones.
But on this guitar it's the ideal solution - although you may still need to enlarge the bridge post holes, it would be possible to plug them again if you wanted to reverse it, without it showing.
Check the bridge post spacing, but if it's even close to a standard tune-o-matic then it should fit.
I will look into the trem mentioned. Do you guys know if there will be a problem with the bridge post being able to hold up all the strain from the strings? considering that that bridge mounting points were not originally designed to withstand that pressure..
That's my issue with it as well - it just seems a bit close to the limit for what that size of inserts will support, especially as they're also less deep into the body than the similar diameter ones on a Floyd Rose.
Do you know how thick the maple top is, or if it's just a veneer? You'll be able to tell if you take the bridge pickup out.
