Fender amp advice please
steven70steven70 Frets: 1292
edited April 2018 in Amps
Hello,
After some amp advice please.
After 30 odd years of playing through 'gainy' rock type amps, I recently got hold of a what I understand to be a 59 bassman copy(ish) Turned it up a bit, stuck a boost in front of the thing and ...
This has given me the urge to try a 'real' Fender amp, nothing fancy but something that drives a bit and which I can boost if needed.
I have done some research and am still confused by the different 'Bassman' versions out there- which appear to be different amps with the same name. 'Blackface' seems to be popular recommendation , but even that is confusing.
I don't want to end up with something that is crystal clean and twangy or needs pedals 100%
Can anyone offer any advice as to a reasonable, non bank breaking option. Single channel head, no frills, I have a Rock Crusher so non MV OK, but that's not to rule out modern alternatives (e.g. is Bassbreaker any good a a 'proper' amp?)
I'll have to raid the piggybank and shift my 87x reissue and some other bits & pieces to help. Probably rules out some of the real vintage stuff.
Any thoughts or advice appreciated. Of course if anyone has anything they want to shift, let me know.
Many thanks!
  • There are two main kinds of Fender amp — Tweed, which is dirty, but also very capable of clean warm tones, and Blackface, which get the clean, chimey sound that most people associate with Fender.
    From there some of the tweeds are cleaner than others, and the blackfaces have different characters of breakup.
    I have lots of experience with Tweed Champs and the Princeton Reverb, and not much else, so others will know way more.
    What kind of sound are you after?
  • steven70steven70 Frets: 1292
    edited March 2020
  • p90foolp90fool Frets: 31767
    Swap your 1987x for a JTM45?
  • equalsqlequalsql Frets: 6207
    edited April 2018
    I built myself a tweed bandmaster 5E7 a few years ago and it is warm and punchy up till about 4-5 on the volume, then it starts to break up above that and is glorious. Listen to Pete Townshend cranking one on Don't Get Fooled Again to hear how it chimes. The amps were definitely designed to bring out the best in single coil guitars.. but they turn into monsters when cranked on humbuckers.
  • GassageGassage Frets: 31021
    Very simply, think of this in terms of finishes and colours;
    Tweed- rough and saggy
    Blonde/Brownface- slightly rough but neater
    Blackface- very sharp and clean
    Silverface- more sparkley than black.
    Re your Q- Blondeface Bandmaster or Bassman head.
    edited March 2020
  • 57Deluxe57Deluxe Frets: 7348
    edited April 2018
    Blondes are still Brownfaces (some even Balckfaces). The xx face referrence colour is determined by the control panel colour - not the amp covering.
    <Vintage BOSS Upgrades>
    Does that make my Tweed Champ a ‘chromeface’j?
    edited March 2020
  • ICBMICBM Frets: 72821
    steven70 said:
    What's with the impedance on these things- is it always 2 or 4 ohms? Will that knacker the amp if I run into an 8 ohm cab? I can't imagine if would do it any favours...
    A Tweed Bassman or Super Reverb is 2-ohm and shouldn't be run at 8 or 16 ohms - but it's not usually an issue since these are combos.
    Almost all Fender heads are 4-ohm, and can safely be run at 8 ohms, although you will lose some power and tone. Don't run them at 16 ohms (apart from the very few that are 8-ohm). There are no 2-ohm heads.
    Many modern copies have more impedance options - and if you have a 16-ohm cab with two or four speakers you can rewire it to 4 ohms if that's easier.
      ShinyFace!
    edited March 2020
  • ArchtopDaveArchtopDave Frets: 1371
    steven70 said:
    Thank you again for the advice.
    Very last question from me...
    Can anyone recommend someone UK based who might build a Blondeface Bandmaster or Bassman head copy?
    Cheers
    Try speaking to Chris, who makes Rift Amps.
  • sweepysweepy Frets: 4209
    Definitely talk to Chris @RiftAmps ;
    edited March 2020
  • rlwrlw Frets: 4743
    For a minute, I thought Gassage was describing women.............
  • richardhomerrichardhomer Frets: 24858
    Highly unlikely... :)
