Nice weather for necks?
I have two nice electrics, a Suhr and a 335.  I've not had the latter very long but I've noticed that it doesn't have the tuning stability of the Suhr - or even my cheapo Hofner shorty when we have hot weather.
Given the Gibson has locking tuners and the Hofner's are about as cheap as they come, I can't see why the Shorty seems to hold it's tuning quite well whereas the Gibson tends to have gone sharp when I pick it up the next evening.  The Suhr incidentally is amazingly stable and maybe it spoiled me.
I can think of two possibilities, either the Gibson needs a good setup or maple necks are naturally more stable than mahogany.
Any thoughts?
Thanks
  • WezVWezV Frets: 16726
    this
  • TTonyTTony Frets: 27614
    WezV said:
    this
    Presumably because maple is harder/denser and therefore less susceptible to changes in temperature/humidity?
  • Thanks Wez
    :-bd
    I thought mahogany had a higher density than maple?
    My mahogany necked Godin is super stable, I can leave it for a week+ and it will still be in tune.
  • jaygtrjaygtr Frets: 218
    My les Paul stays in tune well, as does my danelectro whereas I don't bother playing my tele without a tweak as a know it won't be in tune when I pick it up.
    maple is almost always denser than mahogany.  obviously wood varies, and mahogany varies a hell of a lot.
    maple will be fairly stable no matter how its cut whereas mahogany is only really suitable as a guitar neck material when quartersawn, a high percentage of mahogany is completely unsuitable for necks
    there are quite a few variables in this but the most quoted is janka hardness.  certainly tells us something about density but not really stiffness - but that is massively affected by the way the wood is cut
    Janka hardness:
    oh, and lets not forget the actual neck dimensions either.    you would be a bit daft to try and get a super thin neck out of mahogany (well, you could do it with carbon fibre reinforcement)
    fyi when I talk about mahogany I am referring to the traditional south american varieties.   but mahogany is a generic term.  it includes things like sapelle which is a stiffer wood  and more easy to find straight grained quartersawn planks so it makes it more suitable for necks
