The latest build:
NOS caps
Mullard OC44
1% resistors
Sounds absolutely ace...
Massive box though
The box make the layout and work easy, on a board it will take the same space as a Hammond 1590BB or little big muff because the plugs are on the upper slants so out of the way. I will have a go at replicating the layout in a Boss size enclosure.
I need at least 34mm depth, a lot of boxes are 31mm and the battery gets squished, those 1590B enclosures are very very tight. I do not use Eddystone either as the raw box does not look as good as a Hammond.
I wish they had a slightly smaller Octagon, I love that shape and it matches my logo. I have a few bands using these boxes and you can spot them immediately on a pedalboard.
Actually there is not much in it once you take the jacks into account:
Eqd Speaker Cranker clone
Go for it @robinbowes, great results to be had.
What transistor will you use?
